Fuel Filler Hose,Vent Hose Too
hole
Crazy Sr. Respected Jeeper
- Media
- 28
- St George Utah
- 83 CJ 8, 258 I6, T19, 4-1 Dana 300,4.0 Head, Mopar MPI, 10k winch, OME YJ springs w/3" lift,CS 144 Alt upgrade,Locked 20 & 30, Border Collie co-pilots are stock.
Quick overview- Emissions test required for registration renewal, go to test station and emissions end passed with flying colors, but the Evap test failed
. Ok, something/hose on the fuel side is leaking. Every hose was replaced when I upgraded to a 21 gal poly tank, all of them. The roll over valve comes to mind as I had a problem with it 4 yrs ago, and I discovered the plastic nipples are cracked. I completely by-passed the roll over and looped the hoses together, thinking this should fix the problem. Nope, failed again. Came home and looked at every hose well and the only ones that have any visible cracks are the fuel filler and tank vent hose, bad cracks too. When I upgraded the tank I had trouble getting those hoses, in fact, I only found them available from the big box stores offered by Crown so thats where I got them from 4 yrs ago. I'm less than amused that hoses that are only 4 yrs old look worse than 40 yr old hoses
The hoses take a few pre formed bends and I'm not sure if I could just take hose from the parts house to fit the bends I need. Anyone else run into this problem?
