Fuel Pump?
OnTheRocks
My Dad just got an 84 CJ7 , he's been doing a lot of work to it since it's been sitting for quite a while. The problem he's having is, it'll start up and run ok, but the longer it runs, it doesn't want to idle and then is sputters out and dies. He noticed that the previous owner installed an electric fuel pump. Looking at diagrams, he sees that the original fuel pump had 3 lines, on from the fuel tank to the pump, one from the pump to the engine, and one from the pump returning to the fuel tank. The "new" electric pump only has 2 lines, it doesn't have the return to the fuel tank. Could this be causing his issue?
Thanks,
Nate.
Thanks,
Nate.
