Geek Mode ON/
Um.. can I get a ping hereCan someone ping 64.39.131.27? (it is the backup server for 'our' site)...
Thanks!
Um.. can I get a ping here![]()
IP address tested:64.39.131.27Test performed from:Seattle, WATest performed at:2009-11-27 22:49:44 (GMT -05:00)Known DNS records:RN131-27.rose.net
PING results
Host tested:64.39.131.27Test performed from:Seattle, WATest performed at:2009-11-27 22:56:47 (GMT -05:00)PING 64.39.131.27 (64.39.131.27) 56(84) bytes of data. --- 64.39.131.27 ping statistics --- 8 packets transmitted, 0 received, 100% packet loss, time 7000ms
64.39.131.27
Thanks!8 packets transmitted, 0 received, 100% packet loss
And ouch! Thanks!And ouch!
I have a big problem...![]()
Yep - That is the problem...I am not a computer geek, even though I spent 5 years working at IBM I am guessing the 0 received is the issue![]()
load of work, finally figured this one out! My home ISP changed the fiber router block for my IP range and reassigned my IP address!
After aload of work, finally figured this one out! My home ISP changed the fiber router block for my IP range and reassigned my IP address!
It's all worked out now and functioning perfectly!![]()
Fer sure! :wasted:Don’t you just hate it when that happens?:shooter:
