    Thank you for your support!
Geek Mode ON/
Geek Mode ON/
I know what a u/t is, it's that thing spock carried around so that he could understand alien/geek speech!
IP address tested:64.39.131.27Test performed from:Seattle, WATest performed at:2009-11-27 22:49:44 (GMT -05:00)Known DNS records:RN131-27.rose.net
PING results
Host tested:64.39.131.27Test performed from:Seattle, WATest performed at:2009-11-27 22:56:47 (GMT -05:00)PING 64.39.131.27 (64.39.131.27) 56(84) bytes of data. --- 64.39.131.27 ping statistics --- 8 packets transmitted, 0 received, 100% packet loss, time 7000ms
64.39.131.27
PING results
64.39.131.27
Not sure what any of that means... but hope it answerd your questions :)
What we have here, is failure to communicate.:cool:
when I come into the site I go to "new posts" and pick one. after the last entry is read , at the bottom of the page, I scroll back up to the top of the page and click "new post" again and repeat the process. over and over until I run out of new posts.
what I would like to have is a "new post"button at the bottom of the page some place close to the post reply button that will take me back to the "new post" page with out scrolling to the top of the page.:cool:
Thanks! :notworthy: And ouch! :(
I have a big problem... :mad:
I am not a computer geek, even though I spent 5 years working at IBM I am guessing the 0 received is the issue :confused::confused::confused::confused::confused::confused::confused::confused::confused:
The web site is very very slow this morning FYI:eek:
Yep - That is the problem...
After a :dung: load of work, finally figured this one out! My home ISP changed the fiber router block for my IP range and reassigned my IP address! :biggun:
It's all worked out now and functioning perfectly! :punk:
Don’t you just hate it when that happens?:shooter:
