Build Thread Goin Postal
So today I got some decent work done. Got the rear driveshaft all tightened up on both ends, two new belts for the power steering and water pump, put the power steering lines on, ran the motor, put gauges in, tore off the front brakes in prep for the discs too.
The disc caliper brackets I'm getting are coming off of a Dana 44 of the right era, but it doesn't have closed knuckles like the d27 does… So hopefully that works. Also there is a nasty grey sludge coming out of the location where the brake backing plate bracket bolts up with the 6 bolts into the knuckle. Is that that stuff from the diff or just the closed knuckle? I suppose either way I should check inside the differentials and change the oil.
Feels good to have her move under her own power huh? Congrats , job well done. :chug:
Gliryan,
Just curious , on your steering. I see you added some long high steer arms to your spindles and moved the tie rod to the farthest position away from the spindle and put the drag link on the closest position to the spindle, Did you do it that way to slow down your steering?
Yeah it definitely does Pete! I took it around the block just now after getting the front shocks mounted and putting an exhaust of sorts on it.
Tarry thats just the way it ended up. I had my friend make the arms for me and drilled 3 holes on each. Well they ended up being too close together to use any but the outer two. The only reason I installed them this way is because the pitman arm lined up best with that hole, leaving the far forward for the tie rod. And it actually still goes to full lock as far as the axle is concerned, so all is well. Turns around in my driveway super easy, so no issues there.
Lengthened a driveshaft for the front today and installed it, only to find out that it doesn't have nearly enough travel. I think the way the stupid long shackles are make it so that the axle travels front to back much more than usual. Going to have to get some square tube and make a new one...
Yeah man! Cool rig you've got there. Looks good on the trail.
Thanks for sharing the build, keep us posted... get it, posted. :rolleyes:
You did a great job on it I'm very impressed :notworthy: and i'm glad to see you out having fun with it and are proud to say built not bought. :chug:
I think some wise soul told you to do this in November. :laugh: No worries , love what youve done with it so far. Cool project. :notworthy:
:p
stupid hard headed am I. I thought it was going to be more difficult than it has been. It looked like everything was going to interfere with the frame as far as the body. But, turns out it just sneaks past the problem points. Next time I get some advise like that I'll be sure to listen more :chug:
No way , you did a great job. Now you had it out wheeling and have figured out things youd like to improve. Carry on. I'll be watching. :popcorn:
:p
You should also consider on your breather a roll over valve. Basically a check valve that prevents fuel from coming out via the breather in the event of an upset. Don't need a fire!
You can find them at any place that sells fuel cells.
Yeah the roll over valve looks like a good part. For now that'll have to wait. I need to buy a ujoint for the steering shaft. $70 later… Right now I've got the tilt chev tilt column in there, just need to redo the lower mount and that will be ready. Can't finish that until I get my joint though because I need the right length and angle of the whole setup. I'm going to cut off the stock cj joint, that will leave me with the 1" o.d. tube of the intermediate shaft. The chev column has a 1" dd end on it. I emailed the place I'm going to order from to make sure that my measurements match the way they measure their parts. Its hot as balls out today, and I'm burnt out.
I got the column on the way to being finished. Then I noticed the front right shackle bushings were a little loose. I tried to tighten them but they wouldn't get tighter. Eventually the bolt stripped. Cool. So now I have to grind and pull that off and get a new bolt. Those stupid stiff lock nuts suck. Pretty sure that caused this.
Linky
Single Needle Bearing Steering Universal Joint 18567
18567[/url]
:)You say you have the 1" DD coming out of the column shaft.......you should go 1"DD to 1"DD u-joint there to a 3/4"dd x 1"dd collapsible steering shaft and then another u-joint near the box that would be 3/4"DD to 3/4"x36spline. ......that is normally how you would get there and keep the angles correct. Angles on the u-joints not more than 35 degrees.
:D:D:D:D
:D:D:D:D
Jesus that sounds expensive for a POOR college student haha. The way it'll be now, shortening the shaft some and flattening the column angle, it'll be no where near 35 degrees. annnnnd forgot what else I was going to mention :rolleyes:
