going from reg. breaks to power booster setup
rollingflat
central il.
'79 cj7 258 t-150 dana 20. '83 CJ7 258 w/ mopar mpi. d-300 twin stick. Both are mostly stock.
hey out there what is involved in converting my CJ7 from none power brakes to adding a brake booster?
thanks for any help!
Here's a conversion kit
Dual Diaphragm Power Brake Booster Conversion Kit for 76-86 Jeep CJ and 91-95 Wrangler by Crown Automotive
thanks for the reply, is this a bolt on install? do I need to get behind the dash or can this all be done from the engine compartment?
I have never done it but it sounds easy. You will have to replace the linkage that connects to the top of the pedal.
thanks for the info sounds like an easy sat. afternoon job!
