Help Grill Removal
Help Grill Removal
Scout1067
Old Time Jeeper
Germany
1981 CJ7, 258, T176, D300, D30 front diff, AMC 20 rear diff, Weber Carburetor, BDS 2.5" lift
Any tips or things I need to watch out for when removing the grill on my CJ7 ? It looks pretty straightforward to me but I have come to learn that nothing is ever as straightforward as it first appears when working on a 40 year old vehicle.
spray a good penetrating oil on all the bolts and take ur time. the center bottom bolt will more than likely spin
Sent from my E6810 using Tapatalk
Yeah, I figured I would start spraying it with PB Blaster a couple days before I go to pull it. I guess I should plan on cutting the center bottom one out and fabbing a replacement?
Sent from my SM-A405FN using Tapatalk
no need. just bend up the center flap and grab a hold of the set nut with chanel locks or vise grips
Thanks for the tip. I will be getting into it the week after Easter with my niece, a budding CJ7 mechanic. She helped me do my one piece rear axle conversion last year.
