Grill Space
Grill Space
Vick68
South Carolina
1973 Cj5 71 AMC 360 4 spd Manual Front & Rear lockers,
1999 F250 extended cab 5spd Triton V10
I'm having a problem, I've put my new to me tub and grill on my frame of my 73 CJ5 and the grill spacing on the cj is off. The driverside has a half inch extra space between it and the frame. Ive taken it off and tried to refit it and still off. Its tight on the frame but off on the space:confused:. Any ideas of whats throwing it off would be greatly appreciated.
A little more info please.
Were the frame, tub and grill all from the same jeep and you took them off for a frame off restore?
can you post some pictures so we can see just how and where the misalignment is.
The grill goes on with only one bolt. that is iin the center but the "nut" is a plate that can be moved around about 1/2" from side to side. The rods can also be adjusted to turn the grill. I measure one side then the other to make sure the sides are the same distance from the fire wall. You can leave everything loose and use the fenders to square things up. Then move the grill to the center, close the hood to make sure everything is square then tighten the ody bolts paying attention to the alignment as you go.
Thanks Hedge, as for more info. The grill and tub are from a donor 73 CJ5 . the frame is my original 73 cj5. I guess Iwill loosen the fenders and the grill up and see if it can get it all to fit properly. This has been my major pain. For everything that I've done on this thing its odd something so simple has been so complicated.
Make sure the center front blot is VERY loose and the nut plate isn't rusted or in some way stuck in place. Other than a bent frame the only place to adjust the front is in the center bolt. Pull the radiator, doing that will make this much easier.
Thanks, that aint a problem I haven't put the motor or the radiator back in. I plan on loosening the fenders and the grill back up tomorrow and see what I can get accomplished hope to get it primed tomorrow also.
The body bushings also have room for adjustment. You can easily move the tub forward up to a 1/2" if it's sitting all the way back.
Good point, I haven't removed an entire body so I didn't know that. Are the body mounts configured like the front with a nut plate that can be adjusted?
I realize this is a pretty old posting, but can Hedgehog or anyone describe what is meant by, "...use the fenders to square things up."?
After replacing the engine mounts and body mounts the front (and last one) was off center by quite a bit. If I line the grill up on the frame hole, the hood will not close. I hope the frame is not bent...
Thanks!
Shawn
If you bolt your fenders onto the firewall, put your fender braces in place and finger tight them, clear the shocks, thread your fender bolts up front into the sides of the grill, place the grill rods and finger tight them, close and larch the hood wiggling the grill into place to get it to latch, then tighten the grill bolt down you should be pretty close. A tweak here and there will be necessary. At least that's how I do mine.
Sent from my Pixel 2 using Tapatalk
Thanks Mitchellogic.
I'm not sure if my problem is that straightforward. I looked at it this morning and saw that the two inside corners of the fenders are at the sam spot on each side of the frame. The grill is right now centered on its hole.
The hood veers off to the left, not aligned. The gaps between firewall and hood are equal.
If I move the fenders and grill to match the hood, the center of the grill will be off by 1.5" or so.
So, I took some basic measurements and here is what I got:
Front frame tip outside to outside - 29-3/16"
The following are measured from inside surface of the body mounting bracket to a straight edge held against the body:
Driver side: 1st body mounting bracket to body skin - 15-1/16"
2nd body mounting bracket to body skin - 12-1/8"
3rd body mounting bracket to body skin - 10-7/8"
I skipped position 4 under the wheel well.
5th position, very back, from frame to outer skin - 11"
Passenger side: 1st body mounting bracket to body skin - 15-3/16"
3rd body mounting bracket to body skin - 10-5/8"
Diagonal 1 - 11' 2-5/16"
Diagonal 2 - 11' 2-1/16"
So good news, but I'm still confused.
Thanks again! I loosened everything up and stopped being an Architect for a bit. Looks like it will all be just fine.
I like your setup - very nice. What purpose does the Glinfiddich bottle serve there on the front?
$20.00
  10.0%
