Gronk MC2100 Installed!!!!!
Dan77CJ7
Denver,303Local
76' CJ-7 4.2L/T-18/d20 d30sua/amc20soa M/T MTZp3 35/12.50/15s mc2100
If it runs good that is all that counts. :chug:
Are you able to do wide open throttle? If it works, it works. I think I would try to come up with a way to line the cable up square with the throttle Pittman. How is spring tension on the peddle, I was surprised how tired my foot/leg would get with too much effort to push on the skinny peddle.:D
I have heard that the V8 cable works better when switching to the MC.
I'll give you a couple clues. You need a longer cable not shorter. The product I mentioned is about 10x smoother than any O.E.M. jeep cable.
Think outside the box a little. :D mike
Clues?? Thanks.....j/k, why do i need a longer cable? does the cable its self need to be longer or longer pull at the carb end? i'v got it working fine, i think! i timed it using a vac gauge, timing light, volt meter for Rpms. i still might look into the lokar cable/pedel. What i do know is that i should of been in auto shop instead of learning how play ping pong in high school!!!:cool:
Hey Dan do you have coolant flowing thru your intake manifold? I see some funny little hose coming out where a 5/8" coolant line should be.
O that..... hummmm thats my "hot coffee hose", i like to have "hot coffee" on tap in the cab. ;)
:laugh: at least you haven't lost your sense of humor.
when the day ends and my Cj runs like a champ and i see that i hook up my canister carb bowl hose the damn coolant system. well friend..... life's good!
