Do you have a link for the Block you used?
Not sure I've seen that kind.
no i dont, i got it from a local marine supply store here in town.
just went out and looked again and there is no name on it???
it has posts for 12 different circuits and the whole block is powered by one incoming hot wire.
all the wires run out a weatherproof grommets in the side of the cover and all i did was line up the fuse holders side by side beside it as they came out the holes. made for sending power to multip;e places really easy as they are 1/4" threaded studs with nuts that ya just put a ring terminal on and tighten down.
look around your local marine/boat supply and ya will be surprised at what they have,i know i was.
