Half Steel Door question.
diddy2003
Old Time Jeeper
Western Massachusetts
1984 CJ-7
35x12.5x15 MTRs;
YJ 4 inch Skyjacker lift w/ Bilsteins;
rebuilt AMC 360, Patriot Headers, Holley Truck Avenger 670 CFM, Edelbrock Performer Intake, Flexalite Electric Fan; Griffin Aluminum Radiator, Dual Flowmaster Delta Flow 40s;
Dana 30 4.10s w/ Detroit Truetrac;
Dana 60-2 Narrowed, 11 inch Ford Drum Brakes, 4.10s Power-Lok LSD; NV4500; Dana 300 LoMax 4:1 Twin-Stick; Navajo Power Brake Booster
NV4500 gear ratios
1st gear: 5.61 : 1
2nd gear: 3.04 : 1
3rd gear: 1.67 : 1
4th gear: 1.00 : 1
5th gear (overdrive): 0.75 : 1
Engine speed at 55 mph: 1624 RPM
Engine speed at 65 mph: 1919 RPM
Crawl Ratio: 92 : 1
They are YJ doors, CJ's never came with half doors.
If you're looking for the interior door skin, you're either going to have to go with an aftermarket one, like the stainless steel or diamondplate kind, or shop around junkyards, ebay or craigslist for used ones, I don't think there is any aftermarket support for OE style ones.
Thanks for the reply. That is what I figured. Looks like I will be searching ebay for a while.
you know I have friends with TJ doors on their YJs, so that may be another source
Well it appears that I am a dumbass, haha. When I went on quadratec the search was filtered because I had my Jeep as a CJ when I searched. When I switched to a YJ this is what I came up with:
900 000 - Replacement Door Panel for 87-95 Jeep® Wrangler YJ 1/2 Steel Doors - Quadratec
Looks like I need to get some additional parts though, like the door pull handles.
I'm interested in these as well. Like to hear your opinion if you get them. Especially like the thinner profile. My door pin inserts are tan though... I was missing a door pull handle. Had one of those velcro grab handles for the roll bar where the plastic buckle broke. Cut the strap to size, installed grommets and, Bob's your uncle, a new door pull handle.
