Has anybody else noticed this?
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
The stage is set, you've got a jeep project that needs everything freshened a least to some degree. You rebuild the Transmission , a couple days no problem. The old engine is tired so you swap in another one that you hope is better, another couple days. Axles are bent, no problem change'em out in an hour or so. Drive shafts are worthless, so find excellent used long ones, get'em shortened and installed, a couple days no problem. But when it comes time to button it up, the perfect throttle spring takes days and days to get right, the simple horn button is all wrong, the tinniest thing seems to take forever to find and install. Then there's the electrical system to figure out. It CAN'T get any simpler than a Jeep ... Right! The big items are relatively simple, it's the small stuff that seems to take far to much time........................... Or am I special in some way.
