Headman Header bolts on 304?
FunTSAR
Ohio
About 6-8 motorcycles, a 65' Impala SS, a Super Duty with da 7.3 liter!, and now a 75' CJ5 / Per serial number w/3speed 3,750lb. GVW w/304 2BBL carb don't know other info yet, just bought it.
Just brought home 75' CJ5 w/AMC 304 . It is missing a couple header bolts on driver side and has that annoying "tic", are these just a normal "bolt" (my SB 327 is) or is it metric or something "unique"?
Do ya know where I can get them, my local NAPA didn't have clue.
Pull one of the other bolts and take it to Napa. Don’t forget to put some anti-seize compound on the bolts when you reinstall.
Both my 360s have 2 different sizes of bolts for the exhaust. make sure you get the correct size and they must be "header" bolts, or you won't be able to get a wrench on them (in certain holes anyways).
You can order the "stage 8" header bolts, they are a great improvement for the "stock" header bolts. Make sure you get the correct engine year, the later ones are different than the early ones.
