Heater hose route
Heater hose route
WillyWillCJ7
Ocala, FL
1983 CJ7 258, 1993 YJ 2.5L both with 4” of lift
When my dad owned my Jeep he bypassed the heater core when it cracked. The water pump has 3/4” hose coming off but the new core (and old) have 5/8” fitting. Can’t find proper hoses online or at parts store....any advice would be fantastic. ‘83 258cu in.
Thanks, you wouldn’t happen to know which hose goes to top/bottom of the core would you?
Top to water pump. Bottom to water jacket on intake manifold
Get the 5/8" ID straight hose.
Put the one end in boiling water and it will stretch enough for the 3/4" fitting.
That adapter is exactly what I used when installing new heater lines. I did not have a line to the manifold though.
Do the water jackets in the manifold do anything besides tell the temp and have a knock sensor?
Keeps fuel/air mix warm after the manifold heater shuts down and keeps the intake from getting hot.
So the manifold heater is just for start-ups until the water gets warm. Ok, is the heater plugged into a computer or just a 12V source?
Works from a relay. Not connected to computer.
Here are a couple of diagrams. In a couple of the FSM diagrams CZ C100 label is the fuse block.
That's beautiful, thank you so much!!
