HEI and factory tach.
Factory (and aftermarket) tachs are neg driven.The factory tach is triggered from the pulse on the pos. side of the ignition coil. ~~
Hei ignition tach is driven from the trigger side of the hei module. The pulse is neither long or strong enough to trigger your stock tach.The stock tach is wired inline to the coil IE batt/tach/coil pos. when you hooked up your coil to the hei you were back feeding the module a voltage level high enough to maybe kill it.
What Repro did you buy and did it fit in the hole in the dash?All I can tell you is I followed the Painless instructions to re-wire an old tach to the HEI and it caused major disruptions in my ignition. I pulled the tach plugged and she purred just fine. Fortunately I didn't damage anything, but others have roasted coils doing this. Maybe you can use an old tach with the heavy gauge wires, but I could not. I bought a repro for $60 and it worked perfectly with the HEI.
so you used this tach connection on the cap?Might be a little late, but i was perfectly able to use the stock tach with my HEI DUI upgrade...
let me know if you still need some help...
~ Jr
17215.02 by omix-ada, nice repro, fits original dash, got mine from amazon
