HELP! carb built by girl having issues! :(
76cj7chick
Old Time Jeeper
- Solutions
- 1
- WA
- 1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
So.. Being a crazy girl I decided to purchase a junkyard motorcraft 2150 carb rebuild it and install on my 76 CJ7 jeep.. -I installed a intake manifold and exhaust manifold for later years with 2 bbl)...
Once the fuel reached the carb the jeep started
... But then the exhaust manifold started to get hot and smoke appeared...
I shut off the engine adjusted the choke pull off screw by five turns in thinking it had too much vacuum... Started him up again and this time gas flooded out the float bowl vent hose to the charcoal canister and spewed on the ground..
I shut if off again... Noticed fuel coming out between the gaskets too...
Anyone know what may be wrong? (Besides a newbee-girl building a cj7?
I torqued the intake and exhaust manifold bolts to spec and did it in the suggested cross pattern..
Both idle mixture screws are 1.5 turns out from seat
Have 1.08 venturi 2 bbl mc 2150 carb with 48 jets (Live 350-700 above sea level)
Did strip carb -cleaned out all orifices, changed power valve and all gaskets...
Did NOTICE carb choke housing has a hole on bottom that po drilled out.. Don't know why. (The other heat riser pipe hole has been capped off) Will a little hole in the choke housing cause this much flooding..
Also, I just checked the float and it looks fine (7/16') and floats.. I noticed that the gas is coming out between the power valve and throttle thingy (name?) more than anywhere. I did tighten all screws which weren't as tight as they could have been..
Please help a "dumb" about carbs girl...
... This
