help ID lockers?
help ID lockers?
Dan86CJ7
Mass
1986 cj7 258(rebuilt motor/comp cam/weber32/36) T5 300 tcase d30 front(locker/4:10s)
AMC20(locker/4:10s),4"lift,33"s
I believe you are supposed to run a higher weight gear oil with lockers. I'm running 85w140 I believe, with a detroit in the rear and lock-right up front. Can't really help with the exact ID though.
thanks, got plenty of 75W140 syn. hanging around the shop so maybe ill just use that.
can anyone help me ID these lockers? Was doing services and my rear makes this god awful snapping noise at times and feels like it sends the *** end to the side a bit...Are lockers rebuildable/Do they offer service parts? require any special fluid/additive?
thanks for any help/info:D
:)Last two pictures Look like a Positraction housing............has disc's inside , they do require a special additive to the oil..............Not sure what the first two pictures are.
:D:D:D:D
:D:D:D:D
i dont see discs? just a butt load of spider gears? will any Limited slip additive work? have the mopar stuff..
Edit:bottom to are the front,top are rear.
Someone else here will chime in hopefully. If it is a full case automatic locker like a Detroit, I believe you just run heavier oil. If it is a "Positrac" unit then I believe there is a special oil like Tarry pointed out that you have to add into the fluid. Someone who knows these things better should be able to identify and steer you correctly, as I am not even truly sure what all the difference in an automatic locker and a "positrac" unit are..
Sounds normal for a locker. The Detroit Locker is noisy as it locks and unlocks making some people think there is something wrong.
Detroit Locker in rear
And is this next one in the front. Looks Like a Power-Lok:
Check out this link for more info: http://www.jeep-cj.com/forums/f105/lockers-limited-slip-differentials-12434/
What you are describing sounds normal. No need to rebuild anything.
The PO set your jeep up for aggressive traction. But aggressive traction comes at the cost of directional stability. As you found out a little too much gas on a turn when you have a locker in the rear can cause the rear to slide out and fishtail.
I often say a locker can always keep you moving but not always in the direction you want to go.
EDIT: They have come out with a newer version of the Detroit Locker that is quieter. They call it the SofLocker.
Also, the Limited slip you have in front needs an additive like this: ADA.webp
The locker in the rear doesn't need any additive.
thanks dave, always good info!! gonna use 75w140 syn fluid...do you know if the current mopar additive will do in the front??
Yes, I assume you are talking about this Limited slip additive:
The synthetic oil will work great although in all honesty I never use synthetic in my axles or gearboxes. It's my opinion that traditional oils are fine for gears. Just my opinion. If you already bought the oil don't bother returning it.
yes thats the stuff...work at a jeep dealer so i have it available. And in most cases...its free.
If you get a discount you can use synthetic. If it's free send me some too :D
thanks for the help dave:chug:
