help ID lockers?
help ID lockers?
Dan86CJ7
Mass
1986 cj7 258(rebuilt motor/comp cam/weber32/36) T5 300 tcase d30 front(locker/4:10s)
AMC20(locker/4:10s),4"lift,33"s
I believe you are supposed to run a higher weight gear oil with lockers. I'm running 85w140 I believe, with a detroit in the rear and lock-right up front. Can't really help with the exact ID though.
thanks, got plenty of 75W140 syn. hanging around the shop so maybe ill just use that.
:)Last two pictures Look like a Positraction housing............has disc's inside , they do require a special additive to the oil..............Not sure what the first two pictures are.
:D:D:D:D
i dont see discs? just a butt load of spider gears? will any Limited slip additive work? have the mopar stuff..
Edit:bottom to are the front,top are rear.
Someone else here will chime in hopefully. If it is a full case automatic locker like a Detroit, I believe you just run heavier oil. If it is a "Positrac" unit then I believe there is a special oil like Tarry pointed out that you have to add into the fluid. Someone who knows these things better should be able to identify and steer you correctly, as I am not even truly sure what all the difference in an automatic locker and a "positrac" unit are..
thanks dave, always good info!! gonna use 75w140 syn fluid...do you know if the current mopar additive will do in the front??
yes thats the stuff...work at a jeep dealer so i have it available. And in most cases...its free.
If you get a discount you can use synthetic. If it's free send me some too :D
thanks for the help dave:chug:
