Help Identify transmission
thistle3585
IN
Thanks Dave. I was told by a local guy that he believes it came out of a J-20. After looking at my T-150 and the T-18 side by side, the adapter plate makes sense. If this isn't an inappropriate question, can you give me an idea as to the value of these? I am looking at moving them along to fund some other parts for my Jeep. These came off a donor engine and I'm not going to be using them. The guy I got them from said they worked fine, but since they weren't in the vehicle I have to take his word for it.
In my area a T-18a with the granny low goes for about $600. Yours would be a bit less if you have to change the input shaft around $400-$450. If it doesnt have the granny low I cant tell you but it wont be worth much. Youd be better off trying to sell it on a full size J-truck site.
So, would $500 for the T-18 including the Dana 20 Transfer Case and bell housing be fair?
In the photos, both the Transmission and Transfer Case appear to have the original metal ID tags under the bolt heads..
If the tags are original, those can be decoded to obtain original model and application information.
FYI
$35.00
  17.5%
