Help Identifying Bracket
FiNorman
Lifetime Supporter
Orlando, FL
1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
Alternator bracket, yes that is an alternator bracket, but it is for a AMC 258 i6 / 4.2l with ac. And you are missing a couple of spacers that go between the bracket and the block. Making it work for just an alternator with no compressor would be REALLY difficult and fruitless. Ask me how I know. :D
Steering column brackets. Yes will work with auto column. You are missing half of the firewall bracket. The other half of the one in the middle. One goes on top of the column the other on the bottom of the column where it goes through the firewall. They both bolt to the firewall and to each other. Same parts as your 85.
