Misc. Name that part
risail84
Houston
84 cj7
It’s a bit tough to confirm from that picture. But, I’d say it’s the coolant temperature sensor pigtail.
What year and is the motor stock?
I think your Jeep originally had a computer-controlled carb, which uses a nightmare conglomeration of sensors and vacuum lines. It's possible that there have been upgrades to the Jeep to eliminate that problematic system. The coolant sensor was part of that original system and is probably not needed anymore, likely due to a replacement/upgraded carb.
The temperature gauge runs off a different sensor located near the rear of the motor on the other side, with a single wire.
Weather Pack connector, not likely native.
  5.0%
