Help identifying odd noise
jalfonso1
Hey guys,
Recently I have noticed an intermittent noise coming from underneath my Jeep towards the rear. It's not consistent at all, but it does seem to appear after driving for any number of minutes.
I would describe the sound as if I was dragging something on the road. (was the 1st thing I checked for and I'm definitely not
Sounds kinda like a type of plastic jug dragging along the road. Sound does not increase or decrease in any gear, including neutral, or when applying brakes or emergency brake. Additionally the sound doesn't change with speed and will appear at random times and go away as well at random.
I first noticed it after driving up a long hill for about 10 mins, when I got to a flat section I heard it for a few seconds then it went away. Now, the last 2 times I have used it it has appeared (and disappeared) at some point during the 30-40 min. trip.
I'm not able to replicate the sound by jacking up the wheels and shifting through all 3 gears or by turning the driveshaft or tires by hand. While I had it on the jack, I removed the tires and drums and nothing is out of place, broken, rubbing or worn. There's about 75% of the pad still left on the shoes.
My first thought was bad wheel bearing in the rear (front has all new bearings, carriers and everything is greased up. Does this sound symptomatic of bad bearings?
Any other common areas I can look for that would produce this type of noise?
I feel like I have checked pretty thoroughly w/o opening anything up. Most recent work I did, over the weekend was changing the Transfer Case rear output oil seal & felt and cleaned and adjusted the brake there. There's no noise or drag there and it is very silent in that area. I actually heard the noise once before I even worked on that.
