Help! Just replaced the intake and exhaust manifold Gaskets
cfgraneto1118
- Media
- 11
- Philly Town USA
- 1977 CJ 5: 258 inline 6 cylinder (4.2L); T18 factory installed four speed transmission; front dana 30 axle, dana 20 spicer transfer case with a dana 20 axle.(I now know that this was originally a Levi Straus Edition.)
Yeah, I know....I am just like every other jackass. I took apart the exhaust and intake manifolds and now I have some spare parts and the baby doesn't want to turn over.
First question, can I just block the rear side of the air pump and thereby disconnect the air injection manifold? Do I need this thing. I believe it is a California emissions thing?
Second, does anyone have a diagram of how all the hoses reattach to each port?
Third question, I have these steel tubing part which seem to lead nowhere. They come up through the second from the front intake manifold "space" and I have no idea where they go. Any ideas.
Forth question, at the base of the exhaust manifold are two connections: on is tapped and the other is bolted (they secure the base of the throttle lever.) The one that is tapped with not "bit" any suggestions?
Carburetor is leaking at the base, which probably means I should have replaced the gasket, duh....
At least the gasket are in place. Any and all help will be greatly appreciated
