Help needed!
IOPort51
- Featured
- 5
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
sound wisdom.
All car systems are grounded to the motor since that is where most of the electrical activity takes place. Secondary grounds to the chassis and another from the chassis to the body so that all your systems are talking to the ground at the battery. If you have a HEI Ignition system it is also a good Idea to ground the Ignition box and distributor back to your grounding path. Also keep in mind that wire size for grounds should be near equal to the positive side it supports. If you have the ability solder all connections.
Good electrical systems work more efficiently when you always use the rule of the "Path of least resistance"
