help with belly pan removal
77 golden eagle
so I would like to remove the pan but on first look I cant seem to find where to support the Transmission , the pan is holding up the trans right? so the trans needs to be supported to remove right? Im sure I can figure it out if I go back out in the garage I can figure it out, but its hot out there, and im sure someone here has the answer....
thanks in advance
thanks in advance
