help with identification
phinleft
Baton Rouge, LA
78 CJ7, Amc 304 V8 - AMC 20, DANA 30, Quadratra Trac TH400, 35" Mickey Thompsons MTZPainted LSU Yellow/Gold. Modified with 4bl Edelbrock Carb.
I usually am a guy that likes stock original cj's. A friend approached me about buying his 78 CJ7 . He bought it for fun with out alot of knowledge and knows it has a small block v8, but doesn't know what type.
How do i determine the engine type, axles types, and Transmission ?
i know i need to change the oil, but don't know what filter to replace. i am a novice. thanks in advance.
Now for the Transmission . What do you have? A 3 speed, 4 speed or an automatic?
automatic
some pix of the engine and Transmission pan will help us.
must be a amc 308 v8. distrib is up front.
automatic
If it's an automatic, I may have to take back by guess about the TCase. In the late '70s a lot of CJs with automatic had the QuadraTrac TCase. That should be easy to verify. The QuadraTrac had an offset rear output. If the rear differential is on the passenger side of the axle then you have a QuadraTrac.
The QuadraTrac always came with a GM Turbo 400 automatic Transmission , an excellent tranny.
pictures are coming. thanks for all of your help.
Since it looks like you determined the V-8 to be a Amc you can look on the drivers side of the block for the size. There should be a number there like AMC 304 , 360 or if your real lucky 401. :D
Thanks for all the help. Photobucket is giving me trouble so pics are out. From the pictures and advice you have provided this is what i have. tell me how I fare for a jeep to start with.
AMC20
Dana 30
AMC 304 v8 - 401
QuadraTrac GM Turbo 400
someone mentioned i would be real lucky if the block was stamped 401. It is. What is the advantage?
Someone mentioned i would be real lucky if the block was stamped 401. It is. What is the advantage?
Wow that is a bigtime bonus. Basically the "Holy Grail" of Jeep motors. Like stated above its about the cubic inches. :notworthy:
if he doesnt have some outrageous price it would be a smart buy i think. especially if your going to make the jeep look original. you dont see original looking jeeps every day, MUCH LESS with that motor
keep us posted with what you decide to do. :chug:
How about 97 more cubic inches to play with? is that a good reason? :)
got it for 4k. not an ounce of rust, which in louisiana hard to find. all gauges work, all new seats, paint is 2 yrs old, got the soft top, soft doors, its in great shape. let the fun begin.
amc 20
dana 30
amc 304 v8 - 401
quadratrac th400
Wait you typed AMC 304 v8 - 401...
On the block what are the numbers 304 or 401?
The 401 is the holy grail of amc v8's it's got forged goodies from the factory.
