Help with T18
Help with T18
Drew6524
Dayton, OH
1979 CJ7, 4 speed (t-18), 258, Dana 20
The 'cap' you have pictured is the Transmission breather. It prevents pressure from building up inside the transmission.
Are you certain it is a transmission issue and not a Transfer Case issue?
I am not certain it is a Transmission problem. The hard shift's made me suspicious but it could very well be a Transfer Case issue.
Can anyone tell me if the T-18 and Dana 20 share oil? I have heard mixed opinions on this topic. The amount of oil drained from my trans would lead my to believe my trans and t-case are sharing oil; whether by design or not.
My jeep has screamed for help on a couple occasions. 1 - the trahsfer case wasn't fully engaged. 2 - the starter motor engaged and wouldn't disengage. The solenoid was stuck in the "on" position. Even though it was a solenoid problem the starter was ruined.
One more ting to check, how is your through out bearing? If your clutch is warn out it is possible that your throw out bearing has been turning and finally simply gave up.
T-18 's are solid transmissions, if oil is present they are very difficult to truly detonate. I would bet on a new clutch.
To remove the top cover I just remove the shifter (with retaining pin), then unbolt the 6 top bolt and pull up? Are there any alignment issues during this?
You shouldn't need to remove the stick, it's part of the top. Take the plunge, it is really hard to screw this up. If the gears move, move'em back, the same with the stick.
$45.00
  22.5%
