High compression 258s?
danleym
Hi all, first post here. First off- I don't have a CJ. But I have a AMC 258 i6 / 4.2l in my 1980 AMC Spirit that I'm in the process of building, and I figured the Jeep guys would have more info since no one really messes with 258s much in cars- seems most guys looking for any performance just drop a 401 in. Also, if it helps establish any Jeep cred, I have an 02 TJ, that has to count for something, right?
On to the question: has anyone here built a high compression 258? Upwards of 9:1? I'm wanting to run as high compression I can. Planning on all the right stuff- 4.0 head, Lunati 262 cam, .060 overbore. Gonna get the quench as tight as possible- probably .040. And adjust the dish on the pistons to get my final compression ratio. I'd like my dynamic compression ratio to be around 8.1:1 (higher if I can), and that puts me at around 9.7:1 static. I'm also at 9,000 feet of elevation.
So how high have you guys pushed compression on a 258? Even better if it's with a 4.0 head. What are the full build specs (or at least a dynamic compression ratio, too)? What fuel do you run? What altitude are you at?
Thanks!
Thanks!
