MDJEEPER
- Calvert County, Southern Maryland
- 1986 Jeep CJ
Mostly stock, 258 c.i.d., T-176 tranny, Dana 30 front, AMC 20 rear, Dana 300 t-case, 31x10.50 tires, 2 inch body lift
I did pick up another fuel pump and gas cap this evening, but haven't installed them yet. Now you've got me wondering if I should even bother with the pump or just return it. Maybe it isn't a pump problem at all, but I'm not sure how I would figure it out.
ThisGuyUKnow: If I try blowing out the fuel lines with compressed air, what PSI do you suggest? Maybe around 40 or 50?
Also, if I blow out the fuel lines (and replace the pump), how much trouble am I going to have getting the system primed again?
Damn...One other thing I keep forgetting to mention...despite a decent tune-up and the other normal maintenance stuff, the Jeep also is getting pretty poor fuel mileage overall, even when it seems to be running fine at lower speeds/on flat ground....
