How hard is it to rebuild one of these things?
Buuushman
- Media
- 7
- Kihei, Hawaii
- 77' CJ-5, 360 c.i. motor, T-176 trans, D-300 transfer case w\ twin sticks, Dana 30 front, A.M.C. 20 rear w/ 4.10's, solid axles & trac-lok, 2.5" lift Y.J. springs.
Well, I got the motor apart and the shaft was seized into the bushing on the back of the casing. Got it freed up and cleaned and it looks like it should be salvageable. The windings, contact surfaces, and brushes all had corrosion but minimal wear so I may get away with cleaning it up and sticking it back together. It looks like this thing did not see heavy use and probably got dunked in the ocean or something and not cleaned and then sat for a long time. I want to try to make my own remote so now I am hunting for a two pole momentary switch and a three prong connector that will work for me.
Hopefully I will have it back together this week- My buddy has some palm tree stumps that need pulling in his yard that would be a perfect field test for this thing.
Thanks for all the help and input everyone,
Bush
Bush
