How much coolant?
How much coolant?
300smk
Montana
82 cj5, 360, t176, d300, dana 30, amc20
AMC 360. Drained my cooling system and flushed it out. I have refilled and drained it several times. The most fluid I can get out of it sitting on flat ground is about 2 gallons. Specs online for a AMC 304 says 14ish quarts. I assume a 360 would be similar. Could anyone with an AMC v8 let me know how much theirs holds? Final flush tomorrow I was going to jack up the rear, see if I can find that last gallon. Thanks
Its in the block, when you drain the rad it doesn't drain what's in the block. It should have drain plugs in the side of the block to drain it.
