Misc. How wide rubber??? Want more meat!
Chipster123
Cottonwood, AZ, USA
76 CJ7
Happy day after Easter, I hope this is the right forum. What is the widest tire I can put on a 15” x 9-1/2” wide rim? Currently have 31 x 10.5 x 15 BFG T/A’s … but they are old…..frown face emoji
I'd say wider than your jeep can clear while turning. I have a set of 15x7 with 33x12.5 R15 how wide are you looking to go
Thank you, besides looks, I’m considering what I find used on C/L, so that’s why. Great info,thank you. Regards. Chipster
I think most common will be the 12.5 range in width unless you get bigger than 15. Once you get to the 35"+ range I've seen 14"+ width but typically on 17"+ rim size unless you order new
The chart shown earlier says “maximum tire width”. It’s actually referring to tire tread width, not overall tire width. 33/12.50R15 tires have a tread width of approximately 10 inches or 250 millimeters. Be careful.
Not to hijack someone else's post but you just answered the million dollar question for me. Running 32x11.50r15 now need new ones wanting to get Thornburg 33x12.50r15 and just wanted to clean up and use the old wagons.
I use factory wagon wheels with center caps for the 31s and an after market set for the 33s
Yup
