Hub & Disc Brake Rotor
Peanut Butter
Full Time Jeeper
Boerne, Texas
The service manual says the 79 CJ7 came with a hub rotor combination that is one part. The major parts catalogs list separate hubs and rotors. :confused: They sure look like they could be separated. But what gives? My hubs are good, but I would like to replace the rotors if possible. :rolleyes: Thanks, Rod
The disk brake hubs are pressed on, which is somewhat of a careful process so the disk does not crack.
Yes, use some penetrating oil, lay it on the floor, put the lug nut on the ends of the studs and hammer away. If need be use a crow bar to separate after the studs are removed. Press the studs in using the new disc.
Or use a press (Dana 44 )
Ok, so Posi your saying remove the studs first and the hub and rotor should separate? Rod
Yep, that's what he's saying.
Yup, what OD said.
Once I removed the studs I just tapped the rotor off with a 2lb hammer. Let it sit overnight in penetrating oil. You don't need a press to install the studs a hammer will do.
Don't install with a hammer.:eek:
'Draw' each stud into place, with a lug nut and washers from the outside.
I've install them a number of ways including using a hammer, without any issues at all.
I've been installing them for over 83 years......:D
:D..
Excellent! Good to see him wearing safety glasses as well.
Show off! :) "I took the opportunity last night to press the studs out with my new HF shop press" Not all of us has a "new HF shop press". :) I've done it both ways, with a hammer and drawing them up with a nut. I always felt like I got a better stud seat with a hammer. I've also done it in sort of a hybrid operation, draw them with a nut then pound 'em with a hammer.
Fail - :D
Shop safety has always been important to me. If you start them out right at a young age they tend to continue as they get older.
HedgeHog: Show off! :)
Yes, I couldn't help myself. Besides, I need to use this thing as much as possible to justify it's cost. :laugh::laugh: Not really, but sounds good to others! Thanks again for everybody's help. :D Rod
$210.00
  100.0%
