Engine I left my 83 CJ 7 inline 6 258 sit for a year. Replaced fuel pump. Now holley carb flooding. Stream of fuel up the vent tube. Replaced
Jordan11
Florida, USA
1983 CJ 7
Question - I left jeep sitting for a year. After replacing battery no fuel to carb. Replaced full filter, fuel pump. Now turns over briefly then signif I can’t flooding from vent on Holley carb. Checked fuel level in float, changed needle and seat, checked pressure 5-6 psi.. not sure what else to do. Very little experience. Any advice? Thanks
What specific carb? You install the carb before or after the hiatus? Old gas? Was it running before the carb swap?
Tons of expertise on here, but they may need you to elaborate a bit on exactly what you did and when you did it
First thought was stuck or faulty float. But you said you checked that already. Other thought is the small rubber o-ring where the float valve seats. Next I would check the accelerator pump. It is a diaphragm with a gasket. Cracked/torn rubber would leak.
Good advice here. Also check the float itself to be sure it still "floats". Years back I had a brass one that developed a pinhole leak and would fill with fuel.
