Engine I need help with what head I have and what I should do moving forward
Weebs74
Waukesha
1985 CJ-7, T-18, twin stick Dana 300, AMC 20 series diff
Putting a 4.0L head on a AMC 258 i6 / 4.2l is a common modification.
Definitely a 4.0L cylinder head as it has rectangular ports for larger valves and better flow while a AMC 258 i6 / 4.2l has round ports.
Does the block casting number contain '444'? If so that is a AMC 258 i6 / 4.2l with a 4.0L head.
I’m not sure I understand… does the head on the engine where I pulled the Clifford header off of and the aftermarket exhaust does that look like the 4 L head?
Specifically, the engine with the valve cover off. That’s the head. I’m trying to identify. I believe the other engine to be a stock head on a AMC 258 i6 / 4.2l L AMC.
BTW just FYI
Boring an AMC 258 i6 / 4.2l .060 inches over is generally considered the absolute maximum limit and is not ideal for a reliable daily driver or long-term build, though it is often done. While it works for racing or mud-bogging, thin walls increase the risk of overheating, cylinder distortion, and cracking.
Just saying.....
Anyone interested in a Clifford Intake and Exhaust for a AMC 258 i6 / 4.2l I6 for sale....
OR a 4.0 Head for sale......
Looks like you have to make a Choice.
If you keep the AMC 258 i6 / 4.2l I6 head and swap it over, I would take it to a Machine Shop and have it gone over. Valve train issues ran with them. Mostly wear issues that New Is Better than OEM.
MY Nickel.95
