Engine I need help with what head I have and what I should do moving forward
Weebs74
Waukesha
1985 CJ-7, T-18, twin stick Dana 300, AMC 20 series diff
Putting a 4.0L head on a AMC 258 i6 / 4.2l is a common modification.
Definitely a 4.0L cylinder head as it has rectangular ports for larger valves and better flow while a AMC 258 i6 / 4.2l has round ports.
Does the block casting number contain '444'? If so that is a AMC 258 i6 / 4.2l with a 4.0L head.
I’m not sure I understand… does the head on the engine where I pulled the Clifford header off of and the aftermarket exhaust does that look like the 4 L head?
Specifically, the engine with the valve cover off. That’s the head. I’m trying to identify. I believe the other engine to be a stock head on a AMC 258 i6 / 4.2l L AMC.
BTW just FYI
Boring an AMC 258 i6 / 4.2l .060 inches over is generally considered the absolute maximum limit and is not ideal for a reliable daily driver or long-term build, though it is often done. While it works for racing or mud-bogging, thin walls increase the risk of overheating, cylinder distortion, and cracking.
Just saying.....
Anyone interested in a Clifford Intake and Exhaust for a AMC 258 i6 / 4.2l I6 for sale....
OR a 4.0 Head for sale......
Looks like you have to make a Choice.
If you keep the AMC 258 i6 / 4.2l I6 head and swap it over, I would take it to a Machine Shop and have it gone over. Valve train issues ran with them. Mostly wear issues that New Is Better than OEM.
MY Nickel.95
Thanks so much for the message. The 4 L head I’ve pulled off looks fantastic. The head gasket looked brand new. No carbon buildup in the combustion chamber. I’m just going to swap that head over to the new AMC 258 i6 / 4.2l L I bought. My next question is whether I should swap the cams as well. I’m guessing let the guy who originally built this motor since he changed the head and did the Clifford intake and exhaust. He probably changed the cam as well. I just wonder if the cam makes a big difference in this setting versus stock.
Why not just drop the whole motor in and roll with it
