ID the Part from the Manual
- Orlando, FL
- 1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
I have an power steering bracket that was gifted to us by Jeepboy45 (thanks again Brian).
Now we are trying to locate the bolts and hardware that will be used to attach everything.
I have located the part numbers in the Jeep Manual, and the plan was to get the identical bolt and washer in stainless steel from Ace or a similar source. The problem is I can find the part number but can't find the description, for example 3 inch bolt 5/16-20.
Does anyone have any idea where I could find this information or know what the size of the hardware that is needed? i specifically need #6, #7, #9, #10, #11, #15.
thanks in advance
thanks in advance
