if your tub is off the frame read this
IOPort51
Featured
Garland Texas
1977 cj-5
2006 Toyota Tacoma
If you have your tub off the frame I need a small piece of information. I need the center to center distance of the two bolts that hold the brake proportioning valve on the inside surface of the frame. I can't get a good line of site on it to measure it with the body on. I need to make a shim plate to stand it off the frame to clear the brake lines for a rock rail mount. :cool:
I haven't had my proportioning valve on the frame for years but I have full access to measure it. I just don't remember exactly where it sits. Is it in front of or behind the motor mount?
I just pulled my tub today. I will get the measurement after I put my kid to bed at 8pm
Ok, I looked at my manuals and it looks like it's right on the inside of the front body mount. The front hole is lower than the rear hole, right?
If so, those holes are 2-5/8" apart.
yes one is higher than the other. Is 2 5/8 across that diagonal?? this is what I need. It sounds good.:cool:
2.680 center to center. 2 5/8.
    Best for votes
    on specific items
$45.00
  22.5%
