Ignition conversion
Ignition conversion
blake5179
Utah
1977 FSJ Cherokee
I really havn't seen one of those conversion kits it quite a while, but I guess it would work. I would think most guys would go for the D.U.I. hei conversion for a whole lot more money. Nice pic of the gas tank btw.
My buddy sourced the parts to a 331 odd fire Skylark (?) through NAPA and saved some money on the conversion. Read up on converting a 225, there is some grinding that needs to be done. Not to worry, this is a track well traveled. He says there was an instant improvement.
Got all the parts for my DSII with TFI coil set up out of the bone yard. Cost me a whopping $41.00 for everything. That was many moons ago but I have never regretted the conversion. I've had one brain box go out on me several years ago. That was the one that came off a mid '70s F150 that I originally used when doing the conversion.
Go "electronic". I doubt you'll ever go back.
The kit in question appears to be simular to a Pertronix conversion. The Pertronix odd-fire kit works just fine and is simple to install and keeps the "stock" look. If you have to have a big HEI unit under the hood go for it. Either one will give great results. The main thing to consider is both use full battery voltage so big increase in coil output potential.Just make sure it is specific to oddfire engine.:) mike
$45.00
  22.5%
