Ignition system questions.
KijanaKiume
Hello yall! I'm stumped and I would love some advice. I have a 74 CJ5 with the AMC 258 i6 / 4.2l . The PO had hacked up the wiring something bad. I have undertaken the job to rewire the vehicle and put the headlights on relays. Working late one night I had a moment of stupidity. I ran the coil power wire from the ignition switch to the negative side of the coil and left the key on all night. End result is i melted a coil and burned up all the electronics in the distributor. I bought a new coil and a new distributor. Installed the new coil and swapped all the electronic parts from the new dist to the old dist and ran a new power wire. Attempted to run vehicle. It will not start now. The coil get extremely hot. The old one would run on 12v. This coil says to use with a resistor . Yall have any ideas what would make it not start or what resistor i would need to wire in? I have power all the way up to the coil when cranking or key on. Thank you in advance!
