Ignition timing keeps changing
GoClimbAMountain
- Southeast
- 80 CJ5 Laredo, 4.2L, amc20, d33, d300
2" lift, 1" body lift
2015 JKU Rubicon, 2.5" lift, 33x10.50 TA KO2, Gobi Stealth rack, Barricade front bumper/winch
1997 TJ Sport, stock
I'm restoring my 80 CJ5 . So far, rebuilt my AMC 258 i6 / 4.2l , new Weber carb, new electronic ignition, new distributor. All vacuum lines hooked up.
Here's my problem. I can get the timing set just right and turn it off, back on, let it heat up, cool down and the timing stays. However, next morning i can start it and the timing will be totally off. I have to readjust it until the next morning when it will be off the other way. This has happened most mornings. Is this a distributor problem? Maybe the vacuum advance mechanism malfunctioning? It can have something like a 20+ degree shift, either way.
I'm chasing it but can't zero in on it.
with all of the above.
