iron duke getting tired... 350 swap!
cass
- Kansas
- 1980 Cj5, 350 chevy (i built myself), T176, Dana 300, stock narrow trac 3.54 axles, locked in the rear, power steering, power brakes, tilt steering, Warn lockouts, 31x10.50x15 AT's, hi lift jack mounted on the front, bed lined tub, firestick cb setup, 5 in hella lights, NO RUST!!
well i serviced the jeep today to find bad news. i took the air cleaner lid off to find it full of oil. so i did a blow by test to find that it has a good amount of blow by. that then led to a compression test to find 125,120,90,125. the hole with 90 had a darker burn on the plug. it has the 2.5 iron duke in it now.
so anyway i have been joking about doing a 350 swap and now its going to become reality :drool: right now i have a T-4 and Dana 300 . i am going to run that tranny for awhile and see how it goes. i have a sm465 and bellhousing sitting out back in the shed if i have to beef up the tranny. so anyway any input will be helpful. i have been reading for days on the swap and it looks pretty straight forward. i am going to go with the andvanced adapters weld in motor mounts. i have my own welder, chop saw, and torch so fabrication is Limited to my brain :wasted:
i cant find much info on the flywheel or clutch setup. im going to assume i use a stock flywheel from the 350 and stock starter. im guessing i use the clutch disc from the iron duke and pressure plate from the 350 flywheel.
