is my rocker aligned right?
mrspacemonkey
Laurel, MD
84 CJ7 2.5L 4 cylinder
I thought this could be old or new, either way was afraid of long term wearing. Earlier today I ordered new pivots and arms just in case. They weren't in stock so I have to wait until Monday. I assume its as easy as backing the bolts out, removing the bridge, pivots and arms? These are not under any pressure that I should be worried about are they?
tighten them evenly , you don't want to distort the bridge. I am thinking that's what happened. the rockers were tightened unevenly and bent the bridge.:cool:
check the push rods for bent and or broken??
Ive seen these bend when trying to loosen them. May actually have a few bent ones in my shop right now. They are cheap enough to replace. I would also pull out the push rods and roll them on a flat surface with a light at the other end to check them to see if they are bent.
Thanks everyone. Saved me some sleepless nights! :) Decided to go ahead and replace all bridges, pivots and arms to be safe.
Will also use Jimbos76cj's tip on checking the push rods.
