Jeep 304 stalling out warm.
k5mma
- Media
- 6
- Washington
- 1979 CJ7 304 4spd, T-18, Dana 30, AMC 20, Hard Top, Steel Doors
1979 CJ7 Renegade 6cyl 3 spd All Original, Soft Top/Doors, Paint: Sable Brown Metallic
1979 CJ7 AMC 304 , 2bbl MC Carb. Parts replaced, fuel pump, fuel filter, plugs, plug wires. Rebuilt Carb, flushed fuel tank, blew out fuel lines. Timing set to 10° advanced. Issue is Jeep runs through normal warm up time 5-7 minutes. Idles fine. Engine runs smooth. Ohms resistance is good on all points. Vacuum lines replaced. Running vacuum advance and Pcv only. All and warm air choke lines off intake. Fuel tanks breather lines blocked off. So here's the issue. When taking off from a stop, shifting up to 2,3,4 or slowing to a stop the Jeep stalls down until the rpms come up. Sometimes dies when slowing to a stop. I've went through the fuel and vacuum to check for low fuel delivery and leaks. Nothing found. Not sure What else it could be unless I blew the power valve, ignition or tuning of Carb is off. Or a miss adjustment of the valves. Any ideas?
