Suspension Jeep CJ Coil conversion...
1badcj8
Silver City New Mexico
1982 1-Ton CJ-8 Scrambler, kinda not stock any more...
1982 Jeep Scrambler... Also not stock any more.
JD Offroad makes a kit, though not specific to CJs. It is a universal kit. Tomken used to make a kit. Don't know if they still offer it or not.
I haven't seen a kit for the CJs there are some YJ options out there. As TSBBC said any universal kit should work :)
My jeep has a YJ frame and my front is 3 link and if I remember correctly I got the brackets from Artec. The other company to check out is Motobilt
So I did some checking and calling. JD Offroad - Closest I could get to that was a company in Germany and a JD Fab that does stuff for trucks... NO Jeep anything universal or other wise. Got a strait up NO from them. I also mentioned Tomken in my first note. Jeff the dude that bought it from the OGs of it is an old friend he sold it a good while back. No response from them at all, dont even know if they are still doing anything. It was a very well laid out shop when Jeff had it.
Artec does make some excellent brackets, top and bottom, I've used them before. Have their rear truss in My big Scrambler. Motobilt was also a NO GO... but offered to let me sift throughtheir endless pages of "builder parts"!
G, is your front link for coilovers or did you dp coils? I did my coilovers in my crawler one but dont want to do coilovers for this one.
Seems like I'm going to have to piece it together, Again... Not the end of the world just not as easy as just putting it together. When I did my 4 link and then re-did it longer WB I used Synergy's rear link setup with Blue Torch Fabs TJ buckets, it was an awesome kit, but they no longer make either of these. Any way thanks, I spec I'll get it all put together at some point. Start buying parts and then when I have it all I'll wonder "what the hell was this for" lol.
My front setup uses ORIs and my rear setup uses rear lift coils from a Jeep LJ.
CJs are getting old, so it makes sense there's no off the shelf kit for them.
You could get a YJ frame, extend it to work with the scrambler tub and then use a Coil conversion kit, or maybe use an LJ frame, or buy a new TDK frame that's setup for coils :)
You might already be aware of these parts sources, but just in case…
Ruff Stuff-
Barnes 4WD-
I was thinking GenRight- but they may only do coilover kits.
$45.00
  22.5%
