Build Thread Jeep CJ for my daughters first car.
We sure could have used it putting them .
Those spindle nuts should be torqued.
I would recommend buying the spindle socket and set to torque.
Inner nut to 50ft lbs while spinning the tire.
Back off the inner nut 1/3 of a turn
Torque outer nut to 50 ft lbs
Technically, your correct. Being a 30 year seasoned mechanic, I've never liked putting that much pre-load on wheel bearings. There is just no need. Tighten them up, spin the hub/rotor a few times, back off the nut, spin it again and then tighten hand tight. That will set the bearing, squeeze the "extra" grease out. Tighten just enough with slip-jaw pliers to get the cotter-pin in. Hub bearings are different than, say, pinion bearings. The pre-load on the pinion bearings keeps the pinion from moving and affecting gear mesh and damaging teeth.
Seeing how 4x4's are lock nutted, they are a little different. The inner bearing adjustment I do the same way as the 2x4's, the locking nut is different, I do torque those to whatever to manufacturer recommends.
One thing you forgot to mention Posi, after torquing the locking nut, you need to bend over the tabbed washer to lock that nut in place. Love your ride Posi! Nice!
If you can set the outer spindle nut torque correctly to 50ft lbs with channellocks your a better man then me.
I didn’t mention the bending the tabbed washer because it was a visual thing (see/do), but good you did as it may help others.
Working with your daughter has to be a fun project, enjoy!
Thanks for the jeep compliment.
Oh, no, I'm sorry, I didn't mean to imply that could set the torque with a pair of pliers. I didn't mean for it to come off like that. My apologies. You are correct though, I DO need to set that torque correctly, you are absolutely correct, no doubt about that. I will be ordering one of those sockets, for sure. And before it hits the road, I'll be torquing them just as you suggested! Thanks for the link, the only one I can currently get my hands on is a 3/4 drive, the 1/2 in drive will be really nice!
The picture of my daughter is when she is taking the hubs apart. I wanted her to get in there and get some of that nasty grease on her hands! It will make her appreciate the nice clean grease it went back together with! :-)
I have a OTC 1901 socket which is 3/4". Seams like at the time I was having trouble finding something in 1/2" drive also. I have a cheap 3/4" socket set I got back in 80 and use that and for my torque wrench I use a 3/4 to 1/2" reducer
PLZ, put a long sleeve shirt on her, to protect her arms when using a torch like that. :notworthy:
Get the hub socket, so the bearing preload can be set 'rite'.
All right......enough about the socket already......I’m getting it with the next order......
Just didn't want ya to forget is all. :laugh: :poke:
LOL!! Probably a good thing......I probably will forget it when it comes time to order. I’ll remember about the same time I hit the “submit” button!
Ordered the socket with my order today! [emoji14]
:eek:
Hope that is the worst of the frame issues.
:eek:
:eek: :eek: :eek: Wow. U da man for being able to handle that :chug: lining that up straight isn't for the timid. Good luck and we are watching !
Thanks! Lining it up should not be much of a problem. I have the sublimely that a body shop would use to repair a frame. Lots of measurements to off of.
I see you already purchased floor panels and what looks like a rear floor riser.
Frame looks in good shape other then the left rear rail.
You still have the bump stops, out here their one of the first things that rust off.
If you care to match the original thickness, inside frame is 1/8" outside 3/16".
