Jeep TH400 Technical Information
Peanut Butter
Full Time Jeeper
Boerne, Texas
Thanks for the details and very good/clear pictures.
Good to know. I have a GM Turbo 400 in mine and am going to scrap the gunk off to see exactly what I have. Thanks!
Thanks for the post Peanut Butter. Great info to be able to search on the site.
So did the PO use an adapter plate to put the BOP GM Turbo 400 on your AMC 258 i6 / 4.2l , then swap the the Transfer Case adapter and output shaft from the original tranny?
No mater what type of GM Turbo 400 you might have, you can be sure you are in good hands with a heavy duty Transmission . Many of the TH400 were found in Chevy trucks, both 2wd and 4wd. The TH400 can handle lots of power and torque. :oops: It was used on big block 454 & 396 Chevys, but was also found on the AMC I6. This transmission with for the most part all mechanical shifting is still used on many different type of vehicles. The newer 4L80 and 4L60 are based off of this TH400. With a book and a video, a person with some good mechanical skills can rebuild this transmission at home, making it one of the most desired transmissions in 4wd wheeling. Hope this information is helpful to you all. :driving: Thanks, Rod[/QUOTE]
Thanks PB, good info for sure! I have the T400 in my 76 CJ and that is one of the reasons I really like the jeep. Seriously heavy duty! And it makes it easy to :chug: while idling down the trail. :D
No mater what type of TH400 you might have, you can be sure you are in good hands with a heavy duty transmission. Many of the TH400 were found in Chevy trucks, both 2wd and 4wd. The TH400 can handle lots of power and torque. :oops: It was used on big block 454 & 396 Chevys, but was also found on the AMC I6. This transmission with for the most part all mechanical shifting is still used on many different type of vehicles. The newer 4L80 and 4L60 are based off of this TH400. With a book and a video, a person with some good mechanical skills can rebuild this transmission at home, making it one of the most desired transmissions in 4wd wheeling. Hope this information is helpful to you all. :driving: Thanks, Rod
Thanks PB, good info for sure! I have the T400 in my 76 CJ and that is one of the reasons I really like the jeep. Seriously heavy duty! And it makes it easy to :chug: while idling down the trail. :D[/QUOTE]Thanks for the good information.
I wonder how hard it would be to upgrade the GM Turbo 400 to include a Overdrive for the highway speeds?
Sent from my XT1650 using Tapatalk
Last TH 400 I put in a car was a 72 383 SBC El Camino it was a brute, had it rebuilt to shift hard and it would bark the tires in every gear. Another id is it's very distinctive pan. Nice write-up.
$45.00
  22.5%
