Jeep won't stay running (ignition maybe).
Rollbar
Florida
'84 CJ8; AMC360 w/Holley 600 CFM mechanical secondaries; TF-999 Auto; D-300; D-30F/D-44R, '86 CJ7; 258; T-176; D-30F/D-44R; '80 CJ7 304 Stock; '74 CJ5 304 Stock;
OK, using test light only.
1. Key on: nothing on the + coil/solenoid either side.
2. Start: + coil = light; solenoid = light on both sides
running from the battery + over to the coil + is the classic "hot wire".
The switch is up under the dash, It is adjustable relative to the key rod. perhaps loosening it and moving it up will give you run power to the coil.:cool:
It is usually a good idea to disconnect the battery when working under the dash, you never know what is hanging around down under there.:D
Thanks, ya i have it to where I can just pull the + lead off the battery for now while working on it. I know the - would be better but I need to replace the + cable anyway.
So I guess I will see where the rod runs and loosen the switch and .....
I don't know the history of the switch but for 10 bucks @ AZone or 18 bucks @ NAPA, I might as well get another one.
But first I would like to run a test wire to the + side of the coil to see if she will run.
Then I will know if it is the wiring (not the right one to the coil) or the switch.
Has to be one or the other.
It sounds like you have a bad ballast.
What ballast?
I don't have one that I know of on any of my Jeeps.
^^ yea, what ballast?:cool:
Never mind, I just noticed what year we're working on.
At least the compartment is super clean! Looks like a well cared for Jeep.
1. I installed a new NAPA ignition switch = same problem.
2. Tried w/the Accell coil = same problem.
3. Took Accell coil out and used old coil = same problem. I know it works, I got zapped big time, don't ask how, wife was cranking it over, but i told her to.
4. I have two extra modules, hooked them up, cleaned the modules/fender for a good ground, ran a ground from the battery - to the modules = same problem.
5. Disconnected modules and tried to fire engine, would not fire. That is the only way I know how to check them at the moment unless someone knows a better way etc.
6. Wind blowing about 45+mph and the sand is very bad, had to quit for now.
7. Still have test light when cranking BUT NOT when key in in the ON position.
8. I'm thinking of stripping all the wires out of the looms and ....... I still have the wire looms from the I-6 setup and the computer harness is still there/computer plug in etc and all ends in case someone wanted to restore it back to factory.
9. At this point I think it would be best to get rid of all the extra wire (under the hood) but I don't know how to do that and not mess it up worse.
Thanks,
Jim
OK, I had the kids help me and just to be sure here are the readings one more time and double checked:
Wires discoed from solenoid.
ON POSITION at the Solenoid:
1. Red to + on battery = 12.2v
2. Red to - on battery = 0.6v
3. Blue to + on battery = 12.8v
4. Blue to - on battery = 0.00v
START POSITION at Solenoid:
1. Red to + on battery = 10.7v
2. Red to - on battery = 2.0v
3. Blue to + on battery = 0.00v
4. Blue to - on battery = 12.8v
on the solenoid, which lug is going to the battery/alternator and which is going to the starter. the red wire should be on the back terminal close to the battery and alternator lug and the blue should be on the front terminal close to the starter cable lug.
the black wire is, I think tied into the neutral switch, do you have an automatic Transmission ?
Check continuity between the blue and red wire on the solenoid and the blue and red wires on the two wire plug on the ignition module.:cool:
"The game is afoot!!"
Sherlock Holmes
I did install a auto 999 but nothing is hooked up to it as far as electrical/back up lights etc.
I'll go out and check w/your post.
$35.00
  17.5%
