Jeep won't stay running (ignition maybe).
Rollbar, could you take a minute and fill out your profile? tell us as much about your rig/rigs as you can. It occurs to me that I don't even know what year you are working on.:cool:
FIXed IT!
Checked the switch re/red white/blue = all work.
Then at the fire wall inside the Jeep I have power except to the red/white wire, looked at the TAC lead, hooked it up and the rest is history.
I never hooked up/plugged in the TAC lead under the dash !!!!!!!!!!!!!!!!!!!
Runs perfect.
Sorry to run you all around for something stupid like a connector but I guess we all learned something from this thread.
I will post pics later.
Thank you so much,
Jim
P.S. Going back out to fiddle w/it, I'll check back later.
Ok, here is the video.
Oil Pressure:
60psi = cold
45psi = warm
24psi = hot
Still have to get the temp gauge & fuel gauge working.
Thank you all for your help.
My U-Tube video of her fired up:
YouTube - '84 Jeep CJ8 AMC360 Tf-999
Had the same problem with jeep not running after I released the key to the run position. I replaced many parts with no luck. By blind luck, just happen to notice that there is a 30 amp fuse under the dash for the coil. Bingo! Replaced the fuse and problem fixed.
$20.00
  10.0%
