Just bought the MC2100 1.8 Carb- And I am wondering about all the vacuum lines
cfgraneto1118
Philly Town USA
1977 CJ 5: 258 inline 6 cylinder (4.2L); T18 factory installed four speed transmission; front dana 30 axle, dana 20 spicer transfer case with a dana 20 axle.(I now know that this was originally a Levi Straus Edition.)
Has any one done this? From what I can tell all that it needs are a line to the distributor (the vacuum advance) and the line to the PCV valve. Am I right? What happens to the EGR valve line that went to the Carter? And how will this effect my air injection in the top of the manifold. Unfortunately, or fortunately, I have the california emissions control manifold that comes from the air pump into the diverter.
I am running a AMC 258 i6 / 4.2l 4.2 Liter with the 6A MSD ignition upgrade and blaster coil?
Pulled the manifolds off and regasketed them and then could not get the stupid Carter to work. It was belching fuel again, this is the second time, so I decided to go with the moderately priced carb upgrade. Am I heading in the right direction other than looking to do the THE HowellTBI upgrade which I plan to do come the end of the summer.
Need this thing as a daily driver and I am seriously frustrated. Any and all direction and help will be greatly appreciated. Thanks in advance.
you have two kinds of vacuum. Ported and manifold. the ported will be at zero at idle and the manifold will be at maximum at idle. The pcv valve will be manifold vacuum, a port below the throttle plates and the distributor will(arguably) be on a ported vacuum. The EGR, I believe is ported but it and the diverter valve for the air injection are controlled by the CTR switch/valve so they are temperature activated. The TAC air cleaner is manifold vacuum with the damper signals going through the CTO switch so the bypass heated intake closes when the engine is warm.
Clear as mudd?:wtf:
I just put a MC2100 on mine and have the dizzy set to 14 deg before and the idle screws closed until I got as close to a 700 RPM idle as I could get. If I tune it for max idle speed it runs between 800 and 1000 RPMs
If you live in CA you better check to see if you can pass the smog nazi with that carb.
I passed the smog nazi with a bolt on catalytic converter and a exhaust manifold that was leaking with like a sieve.....Currently I am in Philadelphia. And I think I will pass there as well...
Sorry I thought you were in CA where it has to be stock or :censored:.
Thank you Elwood you rock....One question: are those two lines running from the inline fuel filter to the tank and vapor return?
Hey, no problem. The line in to the fuel filter is from the fuel pump, and the fuel filter is the stock kind with two outlets, the bigger outlet to the carb, the smaller outlet is the vapor return line to the fuel tank.
Make sure when you install the fuel filter, that those two outlet holes are lined up vertically, the bottom (bigger hole) goes to the carb. The top (smaller hole) is the vapor return to the tank.
Check, install the two outlet stock fuel filter vertically.....I noticed Elwood that in your pictures you have removed all the california emissions. How does it run without the added claptrap? Secondly, I noticed in your pictures that you have two small air filter like contraptions on the vent breather and the PCV valve. These allow for what exactly? And where did you get them?
Thirdly, I noticed in one pictures that there is an outlet in the manifold above the EGR valve that runs back to the rear corner of the intake manifold. What is this
The MC2100 comes this Friday, whooooooopeeeeeee:chug:
Just for the record, the 77 was the last year that did not have a catalytic converter.:D
Oh I wish my engine bay looked like that today.....Got the rebuild, studied the connections, traced the previous idiot owners stupidity, removed the air pump and the emissions poopie, plugged the manifold holes, and then Oh my fing God....The Motorcraft doesn't fit. It seems that the housing of the two barrel to one barrel intake manifold hits the studs.....
Options? Trim the studs of course. Really don't want to do that....Next?
How about a spacer? Anybody, bueller?
The second concern is that the throttle is a pull back and I want to stick with the pull down of the carter. Suggestions...........
Help, I am ready to killllllll someone!:mad:
Well this is a California 77 and it has a catalytic converter.....Scratches head?
First and foremost, I apologize, I am a "visual thinker" and not a great mechanic. I will post pictures. But what I have been fighting with is that I cannot "see" how this adaption works. Yes, Elwood I should have stated that this is a single barrel intake manifold and this is a conversion kit.
I took the old Carter BBl off and put it back on after replacing the gaskets.i bought what looks like a great "rebuild kit" of a motorcraft 2100. I thought one would just have to bolt it on. And, I have found out that it was not the case. Pictures to follow (tommorow)
Ok so I calmed down a little. Work got in the way, but I got the carburetor on today. I hooked up the pull-back throttle bracket that came with this kit. (Don't like it and ordered the summit bracket and a new throttle cable assembly.) Hooked the in line gas filter up horizontally, even though I knew better. Ran the vacuum advance line to the port on the side of underneath the choke and closest to the front of the jeep. Ran the PCV valve hose to the top port behind the choke and teed-off it to the charcoal canister. And it still wouldn't start. Pictures tomorrow since I ran out of light today.
All I can say is, brother I've been there and all you can do is have a :beer: or :beer::beer: and hit it again tomorrow.
Don't worry, we'll get you straightened out :chug:
Which way was that IO, pushing it into the street and resigning it to a carb specialist or the mounting bracket?
